1975 6Hp Johnson
jburz
"Hi, I recently acquired a 197
"Hi, I recently acquired a 1975 6Hp Johnson model number 6R75R. My question is this...where is the water outlet? I don't see where a "pee hole" would be and there is a lot of water movement while in nuetral, my research leads me to believe the water is expelled from the same place as the water intake (lower leg), am I right or way off base? I have a Seloc Manual, and have spent a lot of time looking through this forum, I have gained a vast amount of knowledge and ideas here, thanks for that. From what I was told the motor ran fine but has been sitting idle for the past two years. the motor started on about the eighth pull(in water)I plan to clean and replace parts, starting with the water pump, carb, fuel pump, etc. that people have recomended for similar situations. Once again thank you for all the valuable information this forum provides.
Joe"
Plenty of water exits out alon
Plenty of water exits out along with some exhaust. It does this at the back of the exhaust housing halfway between engine and lower unit.At full throttle most of the exhaust and water exit behind the prop.The main water intake is the screen behind the prop.
"In other words, this model do
"In other words, this model does not have a tell tale indicator on it. The indication of water pumping is a spray out the exhaust hole in the bank."
