bought a 16 ft jon boat with trailer and 40hp motor. trying to repair the motor, had a broken ignition swithch and the blue and blue/white wire were hanging out the front of the motor. Ordered a replacement switch from sierra their pn# mp39760. Hooked up the red wire to terminal B, white wire to terminal S, purple wire to terminal C, and the blue and blue white wire to the M terminals 2ea. This leaves the A or I terminal open, which is the only other terminal to be hot during run. I have the following going on, Starter cranks when key is turned to start, Choke clicks down when key pushed in, Still no spark during cranking. I checked the coils and one was cracked, the other one seems fine, but ordered 2 replacemnt ones from sierra. I pulled the flywheel and one set of points looked burnt, but passed the ohms test, so I sanded both sets and re gapped them. I checked for voltage at the points blue and blue white wire and there is none. There is no voltage to the coils either. The Top Terminal on the relay block near the rectifier has 12 volts but none of the yellow wires 3ea have voltage. The reason I need voltage at the yellow wires is that they run to the Magnet things next to the points. Question that I can't figure out is if the blue and blue and white wire is not hot at the run position of the ignition switch, where is the voltage for the igniton points and coil coming from?
