When installing a new water pump impeller, I notice the driveshaft splines on the top side are quite
worn. Does the drive shaft splines slide directly into the engine crankshaft, or is there a replaceable
part with the female splines between the crankshaft and driveshaft?
I looked on the BRP catalog diagrams, but can't tell.
If worse comes to worse, I may be able to find a different drive shaft, but if there's mating splines
in the crankshaft that are shot, I'll be rowing :-(
Thanks for any clues!
