Re: 15 hp Fouled plugs
Plugs really only foul if you are running too rich or you are running too cold.
First, ensure your low speed valve on your carburetor is adjusted to the proper level. Search for Joe Reeves carburetor adjustment on this site for the procedure. 2nd, if it is not too difficult, confirm that your thermostat is working properly and is not stuck open. You can do this easily, on your motor, since the T-Stat is closed when you first fire it up and the majority of the water spray out the exhaust vent is restricted by it. At the very beginning (1st 15 seconds of run time) the water spray out the back exhaust port is almost unnoticable. You pretty much need to put your hand under it to see if it gets wet. In about 15 seconds it will start to spray out the back exhaust port pretty good if the water pump is working properly. If that same spray amount comes out right away (in the 1st 5 seconds, lets say), your T-stat is stuck open and needs to be fixed. If it opens like I said in about 15 seconds you are good to go with that. The last thing to verify then are the plugs. Your motor specs call for Champion UL81C and many here will tell you to use those since OMC knows best. I personally find that these motors run best on NGK B7HS. I had quite a few problems with the Champions on this motor but have used them on other motors quite successfully. If your problem persists, you may want to go try a pair of NGKs just to be sure. Since your fouling is happening at higher RPMs and not from continuous trolling, I would not suggest going to a hotter plug. This would just mask the problem and probably create a whole slew of new a bigger ones.
A decarb doesn't hurt either, but probably isn't your problem, but since carbon is getting on your plugs (that is what fouling is) you can be pretty sure it is getting on your piston rings as well, so I would want that cleaned out once the problem is resolved.
Good luck.
