Hi all, I have a couple of questions regarding flywheels for these motors.
Do the different ignition systems have a different flywheel? i.e. can the flywheel be taken from a distributor model 500 and used on a later model with the separate coils thunderbird ignition? Also can a flywheel from a pull start distributor model without a charging coil be swapped to a distributor motor with a starter motor and a charging coil? (leaving aside the obvious question of whether the flywheel has a ring gear fitted or or not)
Cheers
Cheers
