"I've got a 1974 Evinrude
"I've got a 1974 Evinrude 115 that will not start.
I just rebuilt both carbs with all new jets, gaskets, and float valves. Rest assured, all of the orfices and pathways in the carbs have been cleaned out. I soaked the disassembled carbs in carb dunk, and blew everything out with compressed air.
I cannot see how it could possibly be the carbs. Fuel pump is working, bowls are getting plenty of fuel.
Installed new spark plugs, 100+ PSI compression on all cylinders. (Anybody happen to know the plug type and gap?)
I have resorted to spraying ether into the intake, and the engine does run for less that a second, then right back to nothing.
I've compared all of the new jets with the orfices on all of the old jets, and they are identical as best I can tell.
Seems like it's a fuel issue, but I cannot see how. I even checked the floats are level with the carbs upside down. New gas/oil, new tank and primer line.
Could the reed valves be causing this? Won't start on gas/oil, but will run on ether? PLease help? If the reed valves were bad, would I still have 120psi compression on three of the cylinders?(one has right at 100psi)"
