1974 99 hp Evinrude
M
MAX CAREY
Guest
"I just got my recently purcha
"I just got my recently purchased motor out of the shop and mechanic said it runs but not good. I took it home and put it in my barrel and messed with it and found that it runs just fine slow or fast as long as the couling is off. When I clamp down the cowling it starts smoking bad and loading up like it was choked. When I remove the cowling it will take about 30 seconds to clear out and then runs ok. The cowling doesn't let in enough air. What could be the problem. I removed the little 1 inch rubber plug down in front of carb but that didn,t help."
"This motor is roughly 30 year
"This motor is roughly 30 years old, did the "cowling " suddenly change?Have you set up a fan to blow away exhaust?"
"Most probably an exhaust leak
"Most probably an exhaust leak into the engine. When cowling on, engine runs on exhaust - no air!"
"this is VERY common,on the 9.
"this is VERY common,on the 9.5's..are u sure its not an older 9.5/..there is a seal that could...be replaced."
"to JWBMARINE In reply, The
"to JWBMARINE In reply, The Motor is a 9.9 HP evinrude 1974 Model # 10424S. Do you still think that it could be a seal causing it to load up with the cowling on. Thanks for your advice. MAX CAREY"
"not from where i was referrin
"not from where i was referring to...about the only place i can think of ,off hand,would be a leaking powerhead gasket,or exhaust gasket...either of those,and you would see an obvious leak tho."
to jwbmarine From Max Carey..
to jwbmarine From Max Carey.. I think I have found the problem with my engine loading up with the couling on. I was running it in a 55gal. barell and the engine is real low profile and was picking up exaust fumes from the barell. I took it out of the barell and attached my garden hose adapter and the engine seems to run just fine. Thanks so much for your help and GOD BLESS! Max.
"TO not a student as you can s
"TO not a student as you can see I think I have found the problem. It looks like you hit it on the head, Exhaust fumes, as it runs fine on the garden hose water supply and no barrell. Thanks for your help. Max"
I guess it pays to have nearly
I guess it pays to have nearly 40 years of experience.Although advizing people via this forum does not have nearly the finacial benefits as my regular job.
1976 9.9 evinrude bogs down ab
1976 9.9 evinrude bogs down above 75percent throttle.it starts and runs fine until you open it up then you have to pull the choke out about halfway or it bogs down. thanks
