Patrickstar74
Originally this motor was pushing my 15 ft fiberglass tri-hull about 7 mph. Found a bad plug wire. Cleaned carb. Changed plugs. Also swapped props(believe old one was slipping). Compression is approximately 120 in both cylinders. Throttle does open fully on water, in gear. Took back out yesterday, ran better then first time. Top speed was approximately 12. I moved the trim to all 4 positions and found what I believe worked best and left it. The motor that was on this when I bought it was a 55 Chrysler and it flew. Till it blew up lol. Ran about 25-26. Planed out great. I didn’t think there would a huge difference in 15 horsepower. So anyway, the prop that the motor calls for is a 10 3/8 x11 1/2. Coincidentally the same that was on the Chrysler. What’s on it is a junk 10 1/2 x 13. Could this be a major factor? It basically seems like if this was a car it had 5:13 gears in it and your trying to cruise 100 on the highway. This is my first boat and boating experience but I believe this thing should perform much better. Especially when I seen a similar boat on the lake yesterday with a 9.9 and he gapped me like I was in reverse. Everything so far has been an improvement so I need a little insight from someone with some experience.
