Chris Carver
Ok, need help! I have a 1974 25hp Johnson outboard model number 25R74
I thought removing the lower unit would be the easiest part, turning out to be the hardest..... I have 2 sets of 4 -9/16" bolts ... one set removes the actual lower unit and the set above that removes the "extension sleeve?" It's just a hollow aluminum shell about 12" long ....
After struggling and removing both sets of bolts I found out I need to disconnect the shifter rod well the only way to get to it is above the top set of bolts there is a tiny little plate held on with two screws that I can remove and I can see where to disconnect the shifter rod.
My worry is since it's up in there how hard is it going to be to slide it back together when I can't get to that little piece to line up the shifter rod so I'm kind of scared of loosening up those bolts.
I will take some pictures tonight when I get homeas for the actual lower unit itself I took a part the propeller and the 6 screws that held everything together and I actually looked at the gears itself and everything almost look brand new! I cleaned up the housing and put everything back together just waiting to figure out how to remove that shifter rod without screwing something up Thanks
