Hi there,
I recently acquired a little 1974 15hp Johnson. After checking it all out and adding a few missing parts. I was ready to test in my barrel. Nothing worked first go. After a carb kit and points clean/adjust I had it running smoothly. It was however getting a little hot. Id already checked the water pump and it seemed to pump water ok. I pulled the thermo and tested it. It opened in hot water and closed back down when colder. It was opening and seemed ok. To be safe I ordered a new one anyway. The new one is a 143 degree F unit. As an experiment I tested both side by side with a piece of string suspended in a pot of water over a hotplate. I brought the water up to temperature slowly and found the new thermo opened much earlier than the old. So I believed this to be my problem. I installed the new thermo with a new water jacket gasket and run it again in my water barrel. No difference. This motor is getting too hot. With the thermo removed it runs cool.
Could I have a blocked outlet passage somewhere? The new thermo seems to operate ok. The water pump seems to be ok. I can probably get away with running it without the thermo where I live but its there for a reason and there must be another issue if its getting hot with the thermo in place. Im going to run it next with the water cover off and thermo out to see how well the water pump is pumping. Im pretty sure that will be ok and Im wondering what to look at next.
any ideas?
cheers
any ideas?
cheers
