Hi I have a 1973 Johnson 2 hp, single cylinder that I use on a small zodiak. Compression is good, nice blue spark, rebuilt the carb and swapped in another float. Hard to start, and will only run on the high speed circuit and then will stall after a few minutes. Tried the baseline settings on the carb and many different adjustments. Also does this model have a water pump tell tale pee'r as there does not appear to a provision for one? Thanks
