Kirknannen
I have a 1973 evinrude model 85393m. I am currently battling a no start condition. Engine has good spark, new plugs. The plugs were replaced due to them being old. Ive taken the carbs off and looked for debris and everything was clean, so reassembled and mounted back on. Still have a no start. Engine ran last year until i had a seal go bad in lower unit. Took lower unit apart and replaced the seal, but now will not start. Can get it to run for a few seconds at times on a quick burst of starting fluid. Looking through the cards, i found 2 of the idle screw plugs loose and tightened them down. Manual doesnt give a adjustment procedure for the plugs. Engine appears to have type 3 carbs based on build, but manual states it has type 2 carbs?
