Spark plugs should be Champion QL77JC4 plugs gaped at either .030 (long life) or .040 (super strong spark).
The 1973 50hp Evinrude model normally has a shaft length of 20" (Measuring from the underside of the transom bracket to the anti cavitation plate just above the propeller).
As such, running on a flushette, the idle should be set at 1000 rpm. When in the water, the idle rpm will drop to normal.
As Bobbie suggests... first thing to do is remove the spark plugs and run a compression check... then with the spark plugs still out, do a spark test.
What are the psi compression readings of the individual cylinders (top cyl is #1). Do not reply with generalities such as the compression is great... or good etc. Be specific.
The spark should jump a air gap of 7/16" with a strong blue lightning like flame... a real SNAP! Does it? Again, be specific.
(Spark Tester - Home Made)
(J. Reeves)
You can use a medium size philips screwdriver (#2 I believe) inserted into the spark plug boot spring connector, then hold the screwdriver shank approximately 7/16" away from the block to check the spark or build the following:
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
This can obviously be modified to a 6 or 8 cylinder setup tester.
