"Just got this motor, been sit
"Just got this motor, been sitting for awhile. Put it on the lake today, motor will start, rev up, then die out. Seems like it is choking out when it dies. Smell of gas is strong, primer bulb will go soft. When I restart the motor, it will rev really high, then run for a couple of minutes in gear, then die again. Any suggestions on what to do to get this motor running right? I did drain the plastic gas tank, cleaned it up, and now letting it air dry to make sure no water will be in the new gas. Also, I did order a rebuild kit for the carb from engine marine, will have the mechanic rebuild the carb when it comes in."
