InstaGator
I just got this motor running and it wasnt cooling properly. I've already changed the water pump and grommet on the water pump housing. I noticed the grommet on the upper end of the water tube was swollen so I ordered a new one. I read that the powerhead had to be taken off to replace the upper grommet and since it is halfway up the exhaust housing my gut told me it didn't. After taking the powerhead off.. I was right, taking the powerhead off didnt help one bit. I finally got the grommet in by putting the grommet in a 9/16 socket and putting it against the housing it went into and using a small screwdriver to push it in through the other side of the socket.. so new upper grommet. Now my problem is I cant get the water tube to go back in. It is so tight that I bent the tube trying to get it back in.. I even used vaseline to lube it up and it still wouldn't go. So now that I am waiting on the new one to get it... How the heck do you get that tube to go back in?!?!
