im goin to be setting the idle screws on a 1973 70hp chrysler outboard and i think i got the procedure right just needing info if its wrong
1, 1/4 out then one at a time turn them out till tit runs rough then back in till it runs smooth then move to next cyclinder... which carb should i start with?
do i use all the turn #'s and use the average?
if this works i will be switching the carbs with carbs from an 85hp and doing the procedure all over again.
carbs and engines are the same from 70-85ph except the main fuel jets?
thanks
thanks
