I have a 1973 25 HP Johnson that belonged to my dad that I just got from my brother. I changed the lower fluid last week and when I run the motor there is a lot smoke coming from the lower unit at high speed. When I stopped the motor and I noticed that there was a lot of milky oil in the garbage can that I used to run the motor in. I pulled the motor out of the water saw milky oil running from a hole just below the fill mark on the lower unit. Motor ran fine with plenty of water going through. What should I do next?
