"I'm pretty much stumped w
"I'm pretty much stumped with this motor. I had the flywheel off, but I put it back on with the #1 piston at TDC and aligned the timing mark on the flywheel with the one on the motor. I then rotated the engine .208" BTDC, and sure enough, the timing mark lined up at 33 degrees, just where it should be. I hooked up the fuel, and turned the engine over with the electric start, but it wouldn't fire. Here's what I have done:
-compression check revealed 115 lbs in top cylinder, 114 lbs in bottom cylinder.
-pulled both spark plugs and visually saw good spark from both plugs.
-poured fresh fuel into cylinders and turned engine over.
The engine would turn over all day, and occasionally backfire through the exhaust.
What the heck do I do next? First, Am I correct that the top cylinder is the #1 cylinder. My Clymer's manual didn't specify that. Next, what do I need to check for linkage adjustments or electrical currency, resistance, etc? I am truly confused with this motor.
Also, the flywheel has two timing marks. One is half the length as the other one. Do I use the longer mark for lining up the timing?"
