mercedglen
I have solved all the previous question with your help and the boat is running very well with one exception. Could I get some ideas that might help.
This is a 120 HP OMC (chevy engine). I has the two barrel rochestor carb. The carb has been rebuilt, new seals for exhaust installed, and an electronic ignition has been installed. The problem is that the engine hesitates when coming up to speed from idle and then takes off just fine. The temp guage never goes above 100 either.
Wondering if someone has removed the thermostat, although not sure this would give the inital problem prior to total warmup. My buddy thinks it is a possible timing problem. apparnetly these engines don't have vacume advance and this is done thorugh I think springs/magnets. I would think this is something simple........We will take it out again under load an see what we can see but any ideas or steps to isolate the problem would be helpful....
Thanks, glen
Thanks, glen
