The older 65 hp engine is having trouble cranking. Starter must not be getting enough juice i also replaced both battery cables.
A. The rectifier appears to drop the voltage .3 volts and drop about .5 aps of current. Bad rectifier?
B. I am now able to get the starter to engage the by instead grounding the negative to the motor itself ( not the battery cable).
What do you think?
What do you think?
