Looking for some help...brand new to the forum, I have a 1972 Johnson 65 HP Hydro Electric that I just replaced the water pump on.....my question is.....there is a round plastic (yellowish in color) sleeve that sits in what I believe is the output hole of the top of the water pump. It seems rest (slightly fitted) in the recess on the top of the pump and then simply slide over the metal tube up inside the upper unit of the engine assembly, is there supposed to be a gasket/seal/O Ring of any type that slides over any portion of the upper tube and/or the water pump?
The reason I ask is that water is coming out of the unsealed portion where the lower unit joins with the engine and not out the top two ports under the engine cover. I have read many posts, watched many You Tube videos and looked at the exploded view of the manual but have not found an answer to my question?
Some of the You Tube videos show a similar water pump that has a screwed down sleeve, however checking my engine there seems to be no area in which to screw anything down to, assuming the You Tube is of a similar but different engine.
Any help is much appreciated.
Thanks in advance.
Thanks in advance.
