This one has me baffled. The lower connecting rod end and cap is larger than the bore diameter preventing installation from the top. I have never seen a piston that you have to install from the bottom? Nothing looks distorted or bearing damage. i had to remove piston assembly from the bottom. Look like more material than you could just grind off to make it work? does this piston install from bottom? need guidance
thank you
thank you
