Howdy!
I recently bought a 1972 ArrowGlass 15' Tarpon II with a 1972 Evinrude 50 HP outboard. I checked the fuel lines and replaced the old fuel with new fuel and changed the plugs (just to be sure and start with a fresh set). I made sure the filter was clean (it was) and made sure the fule lines were feeding the carb.
I got it started with Starter fluid and once it starts, it runs fine. But it has to be started by spraying Carb Cleaner or Starting Fluid (I am going to just get a spray bottle with gas/oil mixture in it from now on while I'm trying to figure out the problem) and it runs fine, but won't restart until I repeat the fluid spray into the rubber-covered holes over the carb.
A Mercury repairman told me it sounded like the Primer Solenoid was out and not priming the engine when I turn the ignition switch on. I did some research and it seems it may be that or the Choke Solenoid. I do not know how to test either and that is the extent of my knowledge.
Should I just replace both? Any advice or suggestions will be appreciated.
