I have a SN 3448852 and appears to be about a 1972 model. I removed the module in order to replace one of the coils, marking where each wire went then found I forgot where one wire went. It's the wire that goes to the case ground screw in the lower housing. I've checked numerous sites for 110 wiring diagrams but most either show a system with a stator type ignition or don't show that wire clearly.
This model has dual points with two small coils under a red plastic module that is potted on the bottom. Can anyone tell me where the wire to case ground goes? I'm thinking on the module, innermost terminal on the opposite end from where the coils connect, but I'm not sure because there doesn't seem to be enough room.
Any help would be appreciated
