Hi.....thanks for the good advice. I decided to buy another fuel pump ($83) and installed it. It ran a little better on slow idle speeds but it still bogs down at high speed (smokes a lot/ no power). I had paid $210. for a mechanic to look the engine over and they stated on the receipt that they did a "carb. rebuild". I got it home and it ran terrible !!! I decided to take the carb apart and was astonished and quite disturbed to find out that it still had the 40 year old gaskets in place, old cork float assembly, etc.......apparently all the mechanic did was spray the inside of carb with cleaner and then reinstall it, and all for $210. !!! I just bought a carb rebuild kit and will do the job myself. I believe the high speed jet & orifice plug/valve seat in float assembly wasn't removed & cleaned so I will replace them when the kit comes in and hopefully it will run at high speeds. The mechanics manual also shows how to nock out the 2 core plugs and put new ones in which I will attempt since those areas will be cleaned better after they are removed. The manual states to use a "Sealer 1000" around the outer edge of new core plugs but watching u-Tube on TV last night, every mechanic I saw that did a core plug removal just punched a new one in without any sealer......any comments anyone ? I'm also going to try and take apart the leaf assembly as you mentioned since the mechanics manual states there is two orifices/valve openings on outer edge of the leaf plate and one apparently has a screen in it and that those should also be cleaned. If I hadn't been duped by the mechanic earlier I would be enjoying this more ! I really like working on things to try and get them running again and will never give that Marine store any future business as long as a live and I will make sure the locals I talk to know about their shady business practices. Again I want to thank everyone who has responded to my post in the past and I have listened carefully to what each of you have stated. One person also mentioned that the poor performance might be "leaky" or bad insulation on the coil windings under the flywheel but other than doing a visual check for cracks I really don't know how to determine a bad coil. I just assumed if I'm getting spark to plugs and the engine is running, that the ignition part of it was OK but maybe it needs some timing parts also like points, condenser, new coil windings, etc. One last note; I ordered points & condensor and a flywheel puller to install them but can I use a car's timing light to check the timing after I install the points & condensor? Thanks everyone for all your help....Eric
