Just bought boat and had it out on water. Ran good for 10 minutes then had only half throttle before in would just bogg down. Fix this problem with a carb clean and fuel pump. Also had to put on a new starter. Replaced the water impeller as well.
Had it back out on water WOT and it ran good for ten minutes then just shut off. (just like someone turned the key off). Started trouble shooting--- no spark.
Compression is 110 on three and 95 on the other. Using manual to trouble shoot but can't get it to spark. I have the CDI pulse pack 113-8362. Everything checks out except the coil. The pulse pack checked out OK. I could not get the coil to spark. The coil had a high resistance 125 OHMS so I think it is bad.
Removed the coil for inspection and it had a crack on the bottom. Ordered a new coil.
I also noticed during my inspection that the clipper circuit is still installed. I have a copy of the CDI installation and troubleshooting guide off the internet. It states to remove any clipper modules. On my parts list item #88 states Clipper circuit assy. It is still installed and hooked up to the terminal board. Should this be removed?
Any help on the clipper or electrical trouble shooting would be helpful.
