Had this boat for 3 weeks now and I have the same problem.
The boat will go WOT at first about 5 to 10 minutes then slowly lose power until your trolling.
Did all the checks, compression is good. Pulse pack checks out. Wiring seems right.
At first I thought it was a fuel issue and I rebuilt carbs and replaced the fuel pump (was leaking). Changed plugs from the NGK surface gap to the Champion JC4. Ran better but the problem is still there.
Replaced a starter (went bad) previous owner did not know how to use the automatic chock and wore the starter out.
On the 5th test drive motor died like someone turned off the key. Trouble shot that to*a bad coil. Previous owner tightened*the coil down to hard and*cracked it.
Motor fired right up after I put in a new coil. Removed the clipper circuit and motor backfired and would not start.*Put clipper in and started right up but motor would not shut off. Trouble shot that to a open blocking diode on the remote throttle. Related maybe??
Next test drive ran alot better. Had it*up to 5500 RPM's and 32 MPH. Held it there for quite awhile. (10 minutes)*Did several hole shots. Seemed fine then it started to miss again at high speed and slowly gave it up until I was at trolling speed.
I am thinking pulse pack now. I hate to do it because it checks out but*everyone is saying they usually solves the problem. Not always though. The previous owner said he had replaced it but I don't know how*long ago. I have the CDI 113-8362 pulse pack.
I was thinking maybe it could be the temp*sensor. I was thinking on pulling the two wires off the terminal board and trying that since it happens when it gets warm. It is not overheating. I can touch the flywheel with my hand for 6 or 7 seconds. In addition I replaced the impeller and lower unit oil with type C.
Also had the flywheel off and eveything looks good. I did find the ignition coil wire was stripped of its screw in and I replaced the wire with a new one I received with my new coil. It did run better but same problem.
Does anyone have any ideas.* This motor runs great for 10 minutes then slowly gives it up. It doesn't die but runs real rough. Tomorrow if I take it out it will probably run great for 10 minutes and do the same.
Temp issue, pulse pack issue?* Why couldn't I keep the clipper off.
