Serial # 3274177 115 hp blue band mercury.
flywheel has a three dots in a vertical row as a marker. Nothing else.
1. Should arrow on distributor pulley point at dot mark when correctly aligned?
2. sticker on motor reads max timing 23 deg, btdc. sticker on flywheel shroud, with degree markers shows max timing in a range of about 15 - 20 deg. What's that about? 23 deg. is beyond the reference "range" on the shroud (flywheel cover) sticker. Also, isn't a 5 degree "range" kind of sloppy?
3. There is no reference at all on any sticker anywhere on this motor indicating where the idle speed timing should be. What's that about?
I understand that max timing has to be dialed in with a timing light while running the engine under load.
Any information would be greatly appreciated.
Thanks.
Thanks.
