1972 100hp johnson,carb problem
herothor
Ok me again,my engines got two carbs i can tell bottom carbs working,the top carbs bowl is fill ing up with gas but its not coming out of the jets in front of the butterfly's can any one help me out*********Going to have a hellof a bomb fire if i cant get this thing runing
Pull float bowl drain plugs on the upper carb and under them are the high speed jets. They may be plugged. Run a fine wire through them and blow them out with some compressed air. They can be taken out but it requires a special screw driver.
yEA Boobie damn things purring like a kittin,i did every thing you said plus adjusted the float a little,,,,shes a hott rod now,thanks man for all the help could'nt of done it without you and a couple of other fellers on this site
