jamesbraun
"Hello, I have a 1971 Johnson
"Hello, I have a 1971 Johnson 60 HP outboard, last year my 20 amp main fuse kept blowing and I had some smoke coming from the control box. This year I worked on it and found all wire to be ok but found a fried rectifier. I removed it and the motor runs good but when I turn it off but keep the key on the main fuse harness gets very hot. In addition I installed a new motorola ignition sytem three years ago.
1.) If I replace the rectifier will that some my fuse and control box problem.
2.) There is a rectangular resin looking box next to the rectifier that I believe if the clipper assmbly, I heard that I need to remove now that I have the Motorola sytem, and if I do will that solve my problem?
3.) Any other ideas?
Thanks very much!!"
Thanks very much!!"
