Been refreshing all the likely wear items on my 1971 Fastwin. Rebuilt carb, resealed the whole driveline, new points, fuel pump, water pump. Put it in the water and got it running (after 24 years hiatus). When it started the cowl under the engine filled up with water right up to the bottom spark plug. Figured it must be the head gasket, so changed that today and it is still leaking water It looked like it was coming out the head...but really can't see where it is coming from. I think I see some bubbling in the water by the spark plug. Anyway, is there something I'm missing or a likely gasket or or forbid a crack that an expert can suggest is causing this?
BTW, I found evidence of a wasp nest in the water pump and all the way into the engine passages by the head.
Thanks in advance.
Thanks in advance.
