1971 evinrude 9.5 just purchased not running correctly
MRCarlson
1971 evinrude 9.5 just purchased, sat for 2 years started up fine and ran great engine sounded great-
once warm slightly warm- engine shut down it would re start but then shut down- had to keep choke on- i was thinking clean out insides carb and fuel system with seafoam or something similiar and see what happens any ideas
No ideas but the facts are -----Check to see if there is spark that will jump a gap of 1/4" or more on both wires.--------Pull the carburetor apart for cleaning and pull the flywheel to inspect for cracked ignition coils ( very common ) , ignition coils that are cracked need to be replaced.
Thanks everyone- will pull apart and check and clean carb.
do not have flywheel puller but if need to i a m sure can borrow one
Testing / inspecting is the way to go.--------------------Waterpump working properly ???--------------Fuel pump working properly ???----------------Will spark jump a gap of 1/4" or more ???------------Thermostat inspected ? installed as many folks take them out for some reason.---------I own about 10 of these motors , so know a few thing about them.
The water pump is really streaming out the water and when running it sound like a big bore 2 stroke. I will start on it once the weather cools down- was just outside push mowing around the pasture field- whooped now,.. Was going to go out- however dont want to put the 7.5 evinrude on the boat. i will wait until i can get the 71 running right. some of the lakes around here are fine for fishin with even electric however the 71 should work great on my 18ft tri hull
and thanks again
