1971 evinrude 60 hp electric shift stops
duigald
"After about 10 minutes runnin
"After about 10 minutes running , engine completly dies , but starts straight away again . Problem re occurs after only a couple of minutes . If I leave engine for 15 minutes i can proceed for another ten minutes . Problem is electrical , any suggestions , Coil, amplifier rectifier . points have been re set"
"I would suspect the amplifier
"I would suspect the amplifier. It could be breaking down after it gets warmed up. Also make sure all connection are clean, tight and corrosion free."
