1971 Evinrude 40 HP
W
William V
Guest
"I have engine model 40152G mo
"I have engine model 40152G motor. It has the typical condenser/points setup. The whole stator rotates, moving the spark wires with it. I don't care for this setup all that much, so is there anything I can upgrade to? Aftermarket would be fine..."
yep.....ign modules...magnatun
yep.....ign modules...magnatune---
sierra # 18-5101 they wk very well...
i have been having trbl getting them tho for the last 3 mos.your wires stay w/system...inst new ones.
"That system looks interesting
"That system looks interesting, but from reading the instructions, I don't know how timing is controlled. Could you explain, does timing become fixed? Do they mount below the flywheel in place of the points/condensors? I'm a little confused."
"William , the points are time
"William , the points are timed to the magnets on the flywheel ( hence the term magneto ) and the plate rotates to change the timing relative to flywheel and TDC. This was a proven set-up for some 40 years and it was a good set-up."
"I agree w/Ikia----
I inst t
"I agree w/Ikia----
I inst the modules,on a stator plate that is worn so much,that u cant keep brkr points set,and most are nowdays.There used to be a 'repair' plate/kit avail,but has been NLA,for quite some time."
"ikia, I know how points work
. My question was in regards to how the magnatune ignition modules are timed/get base timing since they eliminate the points and condenser. The points as we know ride on a small cam on the engines flywheel shaft and the moment they open the spark occurs. So how does the magnatune know when to fire?"
"the modules,fire every time t
"the modules,fire every time the magnets,pass the coil for that cyl..points/cond are completely removed...timing is done same as points,..stator plate still rotates."
The magnatune knows how to fir
The magnatune knows how to fire the same way as the points.These units are timed to the magnets on the flywheel and that is the SAME as the points.I know how this stuff works too.
" timed to the magnets &#3
" timed to the magnets " ----- Is that how they came up with the name " magnatune " ??
