N
Nicholas Overacker
Guest
"i just inherited the engine,
"i just inherited the engine, and it needed a lil' bit of TLC being a seventy one. i replaced the head, gasket, fluids etc...but, the only fuel line on the motor was the main feed from connector to pump, i notice that it appears that i need 2 more lines, one running off of the pump and one on the engine itself? there are two male nipples on the engine one above the fuel pump and one on front of the block just bewlow behind the carb, they are two diff size fittings. where do i run my lines to? the on from the front of the block, does that go to the vertical fitting on the carb? and the one on the side of the block above the pump, does that go to the pump? PLEASE HELP> FISHING BEGINS SOON"
