I have to replace the clutch dog on 1971 9.5 OMC that was slipping of gear.
I have some questions:
1. The lower unit Gearcase had small rubber seals around the screws that thread in from the bottom, I looked at the parts breakdown and cannot locate the part #
2. Does any aftermarket supplier sell clutch dogs for this motor.
3. I need an low speed mixture screw knob can you still get those from Dealer?
4. The choke lever bounces back and forth quite a bit does that mean I need new engine mounts?
I was given this motor as payment for some work I did for a friend. I have replaced plugs, new tank, fuel hose, new fuel lines, new fuel pump, new impeller carb clean.
Background on me: very mechanically inclined (Machinist)
