I recently acquired a 1971 60hp johnson. After installing it, we took it for a test run. It idled well, and ran great at full throttle for about 30 seconds and slowly started losing power. Suddenly it shut off. We checked the temperature to make sure it wasn't hot, and fired it back up. We took off, and it died again. We used the electric motor to get to our dive site, and after diving tried to fire the motor back up. Nothing, wouldn't even turn over. I pulled the cowl off, and noticed the fuse holder dangling there and not connected, so apparently that was causing it to die. It fired back up and we idled to the launch. Could the slow loss of power at full throttle have to do with the bad fuse connection, or should I look elsewhere? The carbs are spotless as I rebuilt them before ever firing it up, and all fuel lines/connections are tight. Thanks for any help!
