Hi there, here I am trying to recover an old evinrude according to a restorated 1970 runaboat. The engine sat for long, years, then I had carburators washed, new impeller, oil and hydro fluid, new tank end fuel line, put in the water and started promptly, electric shift ran great (!!!), no smoke, pissed ok from cooling, no heat on powerhead after 10 minutes. But it runs great with no esitation till 3/4 throttle, then seems to loose power, and as I pull back below 3/4 it turns to run great again. As the engine is not worth a deep investigation, help me with some good advices or I will look around for another engine. Thank you guys!
