1971 20hp Johnson MPG
mgjtkt
"Starts on first pull, idles a
"Starts on first pull, idles and w/o throttle fine. Have replaced all hoses under cowl looking for problems. Getting approx. 3MPG at w/o. There seems to be a large oil slick around motor when at dock, but no causes. 50:1 oil mix Is this normal mpg? What should I look for?"
"What RPM are you turning? Mil
"What RPM are you turning? Mileage will vary a lot depending on RPM, boat type, weight, weight distribution prop size and other things.
It is not uncommon to see an oil slick because you are burning oil mixed with gas, the oil and gas mixture will never be completely burned before it is exhausted out of engine."
"Also, 1771 outboards weren&#3
"Also, 1771 outboards weren't built for fuel economy. Gas was cheap & plentyfull back then. Slow it down to burn less fuel."
