1971 20 hp johnson lower gear box
phlyura
How do you remove propeller shaft housing. I see the bolts but need to know if all the gears will fall out if cover is removed also need to know if I need to remove pivot screw on side of housing and if so if I will lose or be able to back without a shifting problem
