Ben Pearson
Looking for some help. I purchased a 1970’s not sure exact year 50hp thunderbolt. The person I bought it from said he has no idea if it runs. So far I have checked compression 130 psi on all 4 cylinders. I replaced the fuel line and new primer ball. Rebuilt the fuel pump. Completely rebuilt both carbs replaced a bunch of suspicious wires. I check coil and tested all spark plug wires. All 4 plugs sparking. Timing is dead on. The spark plugs do not show any signs of water getting into the cylinders. When it is in the drum it idles perfect. When in neutral throttles up. When in the drum it goes into gear perfect and throttles up and empty’s the drum in seconds. Here’s the problem. I’ve been to the lake 3 times. It won’t throttle up in gear in the lake. I can put it in the gear and putter around with no stalling. I’m starting to think this motor is afraid of deep water.
