netracer61
"I recently bought a 1970 Sear
"I recently bought a 1970 Sears 5hp outboard model# 217/58521. I am trying to find a parts list for this motor and a repair manual as well. I am a bit confused about it's method of cooling,I have been told it is air cooled, but I noticed a small water intake just above the prop and a couple small holes farther up on the lower unit. I ran the motor for a minute in a bucket of water and never saw any water circulation.
I would like to repair if it is actually broken, if anyone has part number list for this motor or an Eska cross reference that I can use that would be great.
I would like to find the following parts:
Prop and hardware
points and condensor
carb kit
column gasket set
engine gasket set
impeller???
Here are some of the specifics i am aware of.
Sears Model 217/58521
serial Number 100132
Engine type 643-05A
Spark plug J-13-Y Champion
24:1 oil premix"
Prop and hardware
carb kit
column gasket set
engine gasket set
impeller???
Engine type 643-05A
24:1 oil premix"
