I bought this engine in a box this spring due to the lower unit being disassembled, after a lot of trial and error I got the lower unit right (I was dealing with a newer lower unit and the shifting was backwards from the original, but I figure out a solution). Anyway, got the engine running pretty well and used it 2-3 fishing trips. Last time out it didn't want to fire, just here and there, but it wouldn't run. I've been messing with it on and off for about a month trying to figure out what went wrong, found insulation coming off of the stator wires so I fixed that, points looked ok. Still nothing. Then as I was taking the nut off to remove the flywheel this afternoon for about the 5th time I noticed I had good blue spark when I spun the engine backwards with the tool I was using to remove the flywheel nut. This was discovered purely by accident as I had zip-tied a test plug to the powerhead to check spark since I couldn't spin the engine and hold the test plug at the same time. Still no spark spinning clockwise. I looked at the recoil I had pulled off and pulled the rope a few times to make sure I wasn't going crazy.
Any ideas? Seems that the stator, coil, points must be ok if I get spark, right?
Thank you.
Thank you.
