I have a 1970 johnson 60 hp 3 cylinder 60esl70b and when i hook it up to a new battery i just bought the starter just rapidly spins. Before i thought the jumper just wasnt supplying enough juice and i would hook it directly to the starter and ground on the engine and the starter would engage the flywheel. The battery reads around 12.7 volts but at the starter solenoid i am reading around 12 volts on the battery post when the key is in the off position. There is a wire with a fuse that doesnt seem to be connected into anything and doesnt recieve any vokts in the off position that is conected kn one side to the solenoid. Could this be the issue? I have read somewhere where it is the wiring at fault if the starter fails to engage from distance. Thanks
