I have a 1970 Johnson 60 HP Hydro Electric shift motor, as noted in the title. I have owned it for 10 years now and never could get it running right. In the past month I've got it running everytime you turn the key. However, it now gets stuck in forward gear. If I shut the engine off and turn it back on it is still in Forward. It will not go in reverse what so ever. I have traced the voltage of the blue and green wires at the knife connectors and the controller it putting out the correct voltage for each gear (Forward, Neutral, Reverse). Before I take the lower unit apart I want to have a plan rather then replacing parts left and right and getting no where. If anyone has had the same or similar issues and fixed it, any help would be great appreciated.
-Alex
-Alex
