red_harring
"Gentelmen
I am trying to hel
"Gentelmen
I am trying to help a young friend with a operating problem with this motor. At first I thought it was a simple fuel pump issue and we rebuilt the pump and cleaned the carb, however the issue still exists and it is this. You cap prime the crab with the choke and it will start fine. But as soon as you try to accelerate it dies. If you pull out the choke it will continue to run but not well. I checked the compression and it was 30 lbs with one crank of the starter cord and 60 lbs with 4 cranks. When the starter cord is pulled and you place your hand over the carb intake there is little suction. I visually checked the gaskets and they look to be in tact.The only thing I can think of is that the rings and pistons are bad or the crank seals are leaking. Do any of you have any input for me
Thanks"
I am trying to hel
"Gentelmen
Thanks"
