"recently I got a 1970 60hp jo
"recently I got a 1970 60hp johnson that had been setting for around 6-10yrs. I changed the impeller, checked the plugs, flushed with carb cleaner, put in a 50 to 1 mix and with a little carb adjusting it runs. WOW! Now for the problem. When th motor is in neutral it will idle good and will rev up all the way, but in gear there is a spot when throttleing the hammer forward that it falls on its face. the spot is before half throttle. Any help or suggestions would be greatly appreciated, thank you"
