1970 4 hp 4w70e
wjs76
"hello to all, I just recieved
"hello to all, I just recieved this 4 hp from a friend and thinking about trying to get it going. The motor fires with starting fluid but not with a tank any suggestions? thank you"
"Do not use starting fluid. It
"Do not use starting fluid. It contains no oil.
Instead spray the proper 50:1 fuel mix into the carb intake.
That it fires probably means that spark and plugs are ok but check clean and reset or replace plugs plugs anyway (J6C gapped at 0.030")
Check that you have good strong sparks.
If it fires up on sprayed in fuel mix .
remote tank ... Yes ?
Check that you are priming the carb with the bulb OK. Check that the choke is operating properly. check the setting of both fast and slow running needles (see below)
Next step probably a carb clean and rebuild..
Finally set fast and slow running adjustment according to Joe Reeves insrtuctions:
<font color=""0077aa"">
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle va /lve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, wating for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
When in doubt...use the manual</font>}}"
