R
Robert Smythe
Guest
" I had been experiencing the
" I had been experiencing the forward gear shift lever popping out of gear when starting out of the hole. Once I plane out this goes away. I forced the lever a few weeks ago and lost ALL of my forward gear. I removed the clutch dog and forward gear, and on inspection found only slight deformation on both, but not enough (it seemed) to cause a loss of forward thrust. I found a used set that did not have ANY deformations on them. I installed and adjusted to manual. Is this a known problem on these motors and is there anything I can do to prevent this from happening again? (adjustment, diferent gears and/or dog etc.) I have also installed a hydrofoil but haven't had the time to check it out to see if it helps, yet. "
