Need input about low compression readings.friend asked me to fix his merc 800 from 1969.looking at it:wiring needs replacement same as fuel lines.now i did compression test for him and found #1 175psi,#2 175 psi,#3 30 psi, #4 170 psi.power head was rebuild by PO.now,when i sprayed oil in low comp. cyl.it jumped to 60psi.could this be symptom of stuck ring or its more severe damage.i didint pull transfer ports yet.motor run fine last time it was in water.is there anything else i should try to bring compression to par??
